Neurorad
I'm patching my distributed audio speaker wires in an enclosure.
I've been leaning toward barrier/terminal strips/blocks, but for possibly 80 eventual wires (20 zones, 4 conductors/zone), the cost will be high, and more importantly, the real estate in the enclosure is at a premium.
I've thought of mounting the terminal strips vertically (sideways, sticking out from the back of the enclosure), but this would make screwing difficult (unless there was some kind of release mechanism to remove the strip from the mount). Enclosure is ~6 inches deep, Channel Vision with the 2" ring extension.
1. What type/style of rail-mounted terminal block should I consider? Feed through, double, triple? 5.2mm, 6.2mm, 10.2mm, 12mm, 16mm? I'm overwhelmed by the choices. Standard screw down, IMO, would be better and cheaper than screwless.
2. What vendor? Digikey, Mouser, Allied, Newark. Automation Direct seems to be relatively more affordable, and they offer some online explanations. Grainger seems pricey.
Thanks guys.
Thanks guys.
