Neurorad
Briefly, I'm replacing a central vac hose, and I maybe buying a kit. System is LV only, un-powered attachments.
Some hoses offer a switch on the handle, to turn the vacuum on/off. How does it work?
There are 2 contacts within the wall inlet ring, and bridging them turns the motor on. Is it a PITA to connect the hose to the wall inlet properly, to allow use of the switch on the hose?
FWIW, I'm considering this Broan-NuTone hose. Soft vinyl over steel wire interwoven with nylon cord. I wish it was offered in a 35' length, but nope. 30' or 42' only.
Any hose rec's or reviews would be welcomed.
Thanks a bunch.
Thanks a bunch.
