This board would make an excellent WiFi to MiLight LED RGBW LED strip and bulb controller if it could input over Wifi from an ISY994i HA controller and output UDP packets to a MiLight bridge.
The problem is that the MiLight bridge requires UDP bytes with 100ms gaps between some of them to control colours and brightness.
Is there any way this is possible with the existing firmware or adaptable with a modified version? I don't know enough about UDP protocol to understand this, yet.
Most users are giving up on the LimitlessLED bridges and controllers and changing over to Fibaro controllers to effect this control but the boxes are extremely expensive.
