CAI_Support
Honeywell humidity sensor already has built-in temperature compensation and pressure compensation, I believe.
WebControl actually calibrated the humidity reading curve using chemical chamber from < 10% to almost 90% humidity range. However, whatever the tolerance of Honeywell humidity sensor and WebControl input circuit components tolerance is not adjustable.
If you need very high accuracy, you can compare to a known humidity sensor, then add or delete certain amount from WebControl humidity sensor reading to reach maximum accuracy.
