Sandpiper
Can anyone with some Brultech ECM-1240 experience answer these questions? I have looked at the web site and manual but this information is not easy to find.
1. Does a 240 volt circuit need to have 2 CT’s per channel or can it work with one CT?
2. Can two 240 volt circuits be monitored on a single channel? Example: air handler and heat pump on a split A/C system. If so, how many Ct’s are needed and how are they wired?
3. How are the CT’s wired when monitoring multiple 120VAC circuits? Also, what is the limit when monitoring “multiple†circuits? Can I monitor nine lighting circuits on one channel?
4. What is the input specification for channel 5 when using for voltage or pulse inputs?
i.e. what voltage level is needed and what are the hi low trigger points and what is the input impedance?
5. When monitoring multiple ECM-1240 units via Ethernet, does each unit need its own Etherbee to Ethernet adapter? What is needed to monitor multiple units via Ethernet?
6. What software is needed to record the collected data into an Excel spreadsheet?
