I'm looking for a water meter I can use inside my house to monitor water usage (just like I use the Brultech ECM-1240 to monitor electricity usage).
Unfortunately I haven't been able to find anything, and I'm hoping someone here can help. I would like a 2" Positive Displacement meter with a high resolution automation interface (at least 2 pulses per gallon). Reasonably priced.
Hersey Meters has a 2" PD meter for $500 (ouch already), but when you add the "pulser interface" which produces a pulse every 0.064 gallons (i.e. each nutation of the disc) the price goes up to $1500! Ouch, pretty outrageous for such a simple addition.
Omega sells a FTB8020B-PR 2" multi-jet turbine meter for $620 with two pulses per gallon. Because it isn't positive displacement, I think it will not work well with low flow rates and it'll be useless for supplemental leak detection.
Anyone else doing this type of monitoring? What kind of meter are you using?
Thanks -- Bob
Thanks -- Bob
