There are other devices that use extended commands such as the simplehomenet devices. Also, I think it is important to say that just because there are no devices on the market right now that rely on extended commands, doesn't mean there won't be in the future. For example, specifically mentioned in the whitepaper is the use of extended commands to send encrypted information in cases such as a door lock. Obviously a door lock is going to use wireless communication, but there is no reason it should not have the support of a robust mesh. And future powerline devices which use encrypted commands will definitely need the support of a powerline mesh that supports extended commands.
So I will again bring up the point that the network may seem to work now but it is equally important that you are investing in a network that is future-ready. Since it is now more on topic I will repose the question:
1. Which devices/firmware versions can repeat extended commands? Are you currently shipping any devices that cannot repeat extended commands and if so why?
From the way SteveL phrased his response above (post 17) it seems to imply that the original ("i1") spec was not designed to use extended commands, but the fact is they have been in the spec (whitepaper) from the beginning. Furthermore, I can remember forum discussions in 05/06 about the fact that the reason extended commands didn't work in "i1" was because the firmware in "i1" devices had a bug where the checksum calculation was not performed correctly and thus the (valid) extended commands were discarded.
It is particularly troubling that this has all been swept under the rug and there has been no public disclosure of when the bug was fixed and the answer to the above question provided along with a reasonable path for those with said devices to upgrade them. So again my original questions #2 and #3 naturally follow:
2. Are there any known bugs in current/recently shipped firmwares?
3. What solutions are available for people with legacy devices who wish to have a network that fully supports extended commands (besides adding more access points)?
I think it is important to mention one more time that we are not discussing anything that is not public information by means of the whitepaper.
Let me also say that I like the Insteon technology and products and the above issues are the only things that keep me from being a strong advocate and supporter thereof (read: help generate more customers).
