Hello all,
So I've been messing around with this webcontrol, very cool device, appears to be limitless, if you can figure out how to program it.
Below is the programing for one of my devices I use control the temperature and control the front door.
All works great, but would like to take it to the next level of temperature control.
I would like to have it control the temperature at different levels of degree based on different times of day, kind of like a wall mount electronic thermostat.
Can anyone help me out with this?
Thank you very much, greatly appreciate your help.
START
TSTLT T1 670
CALLSUB HEAT_ON
TSTGT T1 680
CALLSUB HEAT_OFF
TSTEQ OP2 1
CALLSUB MAILON
TSTEQ OP2 0
CALLSUB MAILOFF
TSTEQ OP1[1000] 1
SET OP1 0
TSTGT IP1 0 EM1
NOP
END
HEAT_ON:
SET OP2 1
RET
HEAT_OFF:
SET OP2 0
RET
MAILON:
SET VAR2 0
TSTEQ VAR1 0
GOTO MAILON1
RET
MAILON1:
EMAIL EM2
SET VAR1 1
RET
MAILOFF:
SET VAR1 0
TSTEQ VAR2 0
GOTO MAILOFF1
RET
MAILOFF1:
EMAIL EM3
SET VAR2 1
RET
START
TSTLT T1 670
CALLSUB HEAT_ON
TSTGT T1 680
CALLSUB HEAT_OFF
TSTEQ OP2 1
CALLSUB MAILON
TSTEQ OP2 0
CALLSUB MAILOFF
TSTEQ OP1[1000] 1
SET OP1 0
TSTGT IP1 0 EM1
NOP
END
HEAT_ON:
SET OP2 1
RET
HEAT_OFF:
SET OP2 0
RET
MAILON:
SET VAR2 0
TSTEQ VAR1 0
GOTO MAILON1
RET
MAILON1:
EMAIL EM2
SET VAR1 1
RET
MAILOFF:
SET VAR1 0
TSTEQ VAR2 0
GOTO MAILOFF1
RET
MAILOFF1:
EMAIL EM3
SET VAR2 1
RET
