Ok, so i have my final inspection tomorrow and the last thing i have to do is get my smoke detectors sounding together. Any help is gratefully appreciated.
EDIT: I took a picture with my 40d so hopefully the diagram is a bit better.
I have 2 wire smoke detectors as well as the PRM-2w which is the polarity reversing module.
Here is a (poor) image of the install diagram from the PRM-2w.
Link to full res image of installation page
I'm confused by it. T1 and T2 (3rd ad 4th screw from the left) show "To fire alarm trigger". Under "A" in the box it says "relay" and under B it says "control panel" and "+ bell -" directly under the screw drawing. Note 1 says: "the drawing above shows a bell output with a switched negative. If the bell output is a switched positive, connect the positie [+] terminal to T2"
C and NO (3rd and 4th from the right) show "to panel fire zone" Note 2 says: It is important that the zone loop on the control panel is current limited, when used with a 2 wire loop. Ensure the maximum current of the 2-wire loop on the control panel does not exceed the rating of the PRM-2w (1A @ 2Vdc).
Trigger Input Options:
A: N/O contact closure If a short circuit is detected at the trigger inputs, the module will revers the polarity on the smoke detector loop.
B: Bell Circuit Follower - If a pulsating voltage or temporal pattern is detected at the trigger input T23, the module will reverse the polarity on the smoke detector loop.
