Desert_AIP
I am planning my Omni Pro II install and have a question regarding UPB status tracking.
I was wondering how well the Omni Pro II tracks UPB status when using the UPB mode.
IIRC it does not detect when the load is switched locally.
Is this also true if the local switch transmits?
i.e I have Unit 10 "Kitchen" and link 10 "Kitchen".
When I turn the lights on from the rocker it is configured to transmit "Link 10 On"
Will the Omni Pro II track this status?
If not and I am forced to track status by issuing UPB status messages I have two concerns.
I have around 60 units, if I do something like this (pseudo code):
When Every 5 Seconds
Check Status Unit 1
Check Status Unit 2
Check Status Unit 60
Will that take too much processing overhead with the Omni?
Also will that put too many messages on the UPB bus, and therefore block any other messages from being received?
Do I even need to track the status of every unit?
I can't test this yet. So was wondering if you smart folks had some insight.
Check Status Unit 1
Check Status Unit 2
