JimTolbert
I am in the process of getting my network setup. I am having some stability problems and read somewhere ( I can’t find it now) that the serial network adapter offered more stability than the USB adapter. My main questions are, is it likely that a serial adapter will improve the stability of the network? And, the desktop that I would switch to would also be running Win Xp. Would a later Windows OS be better? I am also considering change to Linix, but I do not currently have any facility with Linix. The software interrogating the network is based on Tim Bitson’s WeatherToys.
Below is my current network. All the modules are reporting consistently expect the temperature sensors. The humidity sensors in the in the same modules continue to report. Note also that modules further out the string from the temp sensors report reliably. If I restart the program ( which initializes the network adapter) I usually get all sensors reporting ( including the temp sensors) for 1-3 hours (polling every minute).
Any other ideas or suggestions?
RiverRidge Weather Station 1-wire network
Laptop running Win Xp in house
USB Adapter for 1-wire network
House Power Injector
Barometer module
150’ run to hoop house
Hoophouse Temp/Humidity module
50’ to Chicken Coop
Coop Temp module
200’ run to field station
Field Power Injector
Field Temp/Humidity/Solar module
Inspeed Anemometer
Rain gauge
Planned additions are a 8 channel I/O board to control irrigation valves and four –six soil moisture modules
Many thanx.............. jt
Jim Tolbert
Jim at SquirrelRidgeFarm dot com
Barometer module
50’ to Chicken Coop
Coop Temp module
Inspeed Anemometer
Rain gauge
Jim Tolbert
