I posted this yesterday on the Powerhome Forum and it hasn't generated any responses. Hopefully I'll get some help here.
I am trying to set up a powerhome trigger on a switch to detect when it has been turn on/off. The switch is controller of two other remote switches (so I can monitor the light status on their LED), as well as a controller of the PLC so I am sure that messages make it to the PLC. When I turn the switch on and off, the LEDs on the other remotes do follow, so I know the links are set up correctly, and I do get group cleanup messages in the PH log, but no group broadcast messages. When I use the remote switches, I do get the group broadcast messages, and I have been able to set up triggers for them. Furthermore, I can control the switch in question from PH via the control button on the device tab of the insteon explorer, so I am sure the device ID is in the PLC. What can I do to detect switch presses on this switch? Is there something wrong with this switch?
