Hi,
Yesterday I received an Elk-M1XSP, Web Mountain SPIM-01 CIM, & aan HAI UPB switch. I installed the switch then connected the CIM to my pc and ran Upstart. I programmed the switch and all worked fine. I then installed and enrolled the Elk M1XSP, Removed the CIM from the pc and connected it to the M1XSP. I wrote a couple of test rules and once again all worked fine. Today I removed the CIM from the Elk and connected it to the pc(wanted to change the led color). Now when I run Upstart, I go to tools and connect to the CIM and I get and error message. Message is...YOUR POWERLINE INTERFACE IS OUT OF DATE. PLEASE REPLACE IT WITH ONE THAT IS VERSION 3.05 OR HIGHER AND TRY AGAIN...I can then do signal tests of the network and all looks ok, But when I try to send to or receive from the switch, I get the same error message. When I connect it back to the Elk, I works fine.
Anybody have any advice or suggestions?
Mike
Mike
