Jul 18 2005, 04:05 PM
Post
#1
Cocoonut ![]() ![]() ![]() ![]() Group: Moderators Posts: 5376 Joined: 12.24.03 From: Las Vegas, Nevada Member No.: 5 |
[Review] Relay 8, X-10 Driven Eight Circuit Relay Module from WGL Designs
by BraveSirRobbin WGL Designs has a new product that will let you switch eight single pole double throw relays using X-10 power line commands! This latest product is named the Relay 8. This unit can respond to X10 ON, OFF, ALL OFF and status request commands. Here are additional specifications of the eight relays:
![]() Here are details of how to accomplish this task with the Relay 8. First connect the (included) serial interface cable to a serial com port on your computer (any computer can be used for this application). Note that you do not need to plug in the Relay 8 included AC adapter for this step. Download the interface software (http://www.wgldesigns.com/relay8.html) unzip this file and run the executable relay8.exe file. You will get a menu screen shown below. ![]() Note that there is a default run time in minutes nomenclature as well as number selections beside each zone. This is a carry over from WGLs Rain 8 series of controllers and is the maximum amount of time each zone will remain on once it is switched (in minutes) provided that the disable default timers box towards the bottom is unchecked. This is a handy feature when controlling items such as a sprinkler system or other critical systems where you want to make sure the system turns off after a set amount of time (in other words the relay will not have to receive an X-10 power line Off signal, it will turn off automatically after this set amount of time has elapsed). Lets continue setting up the Relay 8. For our case we really want to make sure the garage contacts are opened after the on signal as sent so lets change the number selection to the right of zone one to a 1. Do the same for the buzzer (zone 2). Select the proper com port that the module is connected to and then click load module. The settings you entered will be downloaded to the Relay 8 unit. If the wrong com port is selected or communications errors exist a warning dialog box will appear stating this error. Close this software application and disconnect the Relay 8 from the serial cable. {Note: This setup software will use a high CPU percentage if left operating. This should not be a problem as the application was not meant to be used for long term durations.} Now for the installation in the garage. The Relay 8s relay inputs are connected via a removable terminal strip. This is so the Relay 8 can easily be removed in case of needed programming changes. Note that these relays are single pole double throw meaning basically you can have a normally open or normally closed switch. (C is the common or relay swinger, NC is normally closed, and NO is normally open). We will use normally open condition so wire zone ones NO and C contacts to the garage push button switch and zone twos NO and C in-line with the power lead for your buzzer. Now install the Relay 8 on the wall near these wired connections (Velcro works great). Connect the terminal strip to the unit. Plug in the Relay 8s AC adapter. You will need a PSC05 or TW523 power line interface for this unit to accept X-10 signals from the power line. Plug the power line interface into a nearby AC outlet and connect the interface cable between the power line interface and the RJ-11 jack of the Relay 8 module (this cable should have been supplied with the power line module. Note that it is NOT a standard telephone line as the cables between connectors are not wired the same). Now send the L1 ON X-10 command from your Palm Pad remote or table top controller and the garage door should operate. Send an L2 ON command and your buzzer should sound. Note that if you leave the Relay 8 unit in this state that both zones will turn off after one minute (the setting of the internal timer). The Relay8 supports devices capable of sending an X-10 Status Request command (i.e. two way communications). In addition to giving you the power to poll individual relays to determine their on/off status, it also allows a controller/computer (such as an Ocelot or Homeseer software) to send a command to the module then check to see if the command was carried out. If not, the computer can automatically send the command again. Now you have relay control using X-10 power line commands. Plus, you have six additional relays for controlling other items such as sprinklers or voice amplifiers/speakers. The Relay 8 is available from a variety of home automation resellers as well as WGL Designs web site. Their list cost is $149.95 (US Dollars) and includes the serial adapter cable and AC power adapter but not the needed power line adapter and interface cable (this must be ordered separately). The software and instructions can be downloaded from WGL Designs web site HERE (towards the bottom of that page). In conclusion the Relay 8 offers a quick and easy way for the home automation enthusiast to have relay control using conventional and easily available X-10 power line commands. The ability to poll the device for its status should ease the minds of those of us familiar with the particular peculiarities of the X-10 protocol.
This post has been edited by BraveSirRobbin: Oct 4 2007, 11:57 PM |
Jul 18 2005, 05:03 PM
Post
#2
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 606 Joined: 01.25.05 Member No.: 465 |
QUOTE (BraveSirRobbin @ Jul 18 2005, 02:05 PM) . . . Note that this selection has to be a consecutive series of unit codes . . . Very nice write-up, BSR. The consecutive unit codes, though fine for the Rain8, bones me with low voltage lighting. I would like to use it with X10 motion sensors, but the motion sensors need to be on EVERY-OTHER unit code. |
Jul 18 2005, 05:04 PM
Post
#3
CocoonTech Admin ![]() ![]() ![]() ![]() Group: Admin Posts: 8424 Joined: 12.22.03 From: New York Member No.: 1 |
What about disabling the onboard dusk/dawn sensor? Wouldn't that eliminate the use of the second code?
Jul 18 2005, 05:49 PM
Post
#4
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 313 Joined: 05.26.05 Member No.: 722 |
I purchased the Relay8 about 3 weeks ago and have been using it to control my garage doors. I originally purchased it for the purpose of having different zones for my HA announcements. I was to have 3 different zones for different announcements. If I sent an anouncement to 1 zone things worked fine. When trying to send announcements to 2 or more zones is where I had problems. Using X10 to trigger 3 zones presented a timming problem. It was unpredictable as to how long it would take for all 3 X10 commands to activate the relays. Times would range from 4 to 7 seconds. The time was dependent on how busy the powerling was. Part of the problem was PLC traffic from the relay8 itself. It immediatly sent a status report back as soon as it received the X10 on command. This status feature can not be disabled. So I figured that I would use a group command and turn the 3 relays on at the same time. No dice. The Relay8 does not respond to group on commands. . Needless to say that I don not have zoned announcements at this time.
However, I must say that it does perform as advertised an am satisfied. I feel that they should at least mention that group on commands are not supported as I spent a lot of time trying to figure out why it would not work. An e-mail to WGL confirmed that group on commands are not supported. Thanks, T. This post has been edited by TCassio: Jul 18 2005, 05:52 PM |
Lo-Fi Version | Time is now: 3rd September 2010 - 03:10 AM |
