bucko
I have an Elk M1 Gold and just ordered the Vera 3.
My question involves the BEST way to connect Vera to the Elk. I need my Elk RP2 to see and control my Z-wave devices, but use the Vera to do the heavy lifting in really controlling all the Z-Wave devices. But Vera needs input from my Elk since my OC sensors will be hardwired to the Elk. Vera needs to know when the OC's are tripped so it can execute whatever rule for lighting control. Hope that all makes sense.
So, not even having Vera to play with yet, in my mind I thought I would connect everything as follows.....
Elk to Vera USB via a serial adapter cable using the Elk M1XSLZW serial Z-Wave card (which I have yet to order).
Then connect the Vera wan port to my TP Link switcher in my LAN.
I'm thinking this will allow full bi-comm between Elk and Vera with them updating and polling each other so all devices are on the same page. But, I will want Vera to operated lighting stand alone in the long run. My PC will not be on 24/7.
BTW, I also use the Elk XEP, which is already connected to my switcher.
OR....do I just need to connect Vera directly to my switcher and the Elk will see and connect to Vera through the XEP, accomplishing the same thing AND saving me $200 on buying the Elk M1XSLZW? I just don't fully understand how the Elk and Vera communicate with each other. In the end, I don't care if I have to buy the Elk M1XSLZW. I just need it all to work.
Anybody doing this now? What is my best option?
