Hello,
Im currently in the design phase of a home. The structural prints are done, and off for budgeting. Im working on electrical/security/HA. Ill be supplying the HA/Security, so the electrical shouldnt be too far off a regular house.
Anyway, Im not sure 100% the route im going. I was originally going HAI for HA/Security/Audio. Though now Im looking at Homeworks + Security (thinking HAI), and audio controller. My pricing on HAI is quiet good compaired to online retailers.
My main questions are...
Is Hi-Fi 2 good? Im not an audiophile or anything, id just like to be able to listen to music anywhere I go, in any of the bedrooms etc, and have whole house paging (if there was a DND feature that would be great). My builder generally puts in a lower level Nuvo, but he usually only does basement audio. Should I consider a combination of Nuvo instead?
Is there a way to have local input override? Id like to have docks/BT Moduals in each room. Im wondering if there is a way that if you put an ipod in a dock, it will play in that zone, regardless of whats going on else where? I currently have 13 different zones of audio, it would be ideal if I could have 17-18 sources. Sirius, itunes, Local FM, Pandora Radio, and the local inputs. However all the equiptment I look at, shows 8 Source max. I wont be using more then 8 sources at a time, heck id be lucky to use 3 at a time. Id just rather not have the kids (too small now for it) put an ipod etc in a dock, and have the system reject it because someone else is using a local dock/BT somewhere else.
The only way I can see doing this is with relays and outputs off HAI. If I designated a button on the wall to local input and it switched a source. However, that could cut off something to the other rooms. Other way is having locals all go to individual amps, that can be switched out, that would be bad for paging/cost.
Is it possible?
Perhaps 2 HTX2 via Ethernet?
Is it possible?
