pkarmouche
I've read that many people hope to find a way to use existing, HV interconnected smoke alarms to trigger an event on their alarm panel.  But this is either not permitted, not advisable, or otherwise problematic.
What do you think of this solution? I found this device that "listens" for the typical screeching smoke alarm, and lights up a doorway so you can find your way out. In the case of interconnected smoke alarms, they all sound off if one is triggered, so you would only need one of these devices for the entire home.
It is here, $50: UGH: I'm a new member here, so I can't post links... but you can google "thelightthatsaveslives" for the URL.
With a small amount of "hacking", I would think you could wire a relay into the device where it would otherwise light up its LED's, which would then trigger a zone on your alarm panel if the smoke alarms sound.
Thoughts?
Paul
Thoughts?
Paul
