Hello Guys:
I have an ELK M1 system. I replaced an ADT system last year, so much of the wiring was in place.
I have a 6000sq. ft. shop about 800ft from the main house. Because I house my motorcoach, tools, toys, etc. - I decided to tie that building into my home security system. There was already a 10 conductor run from the house to the building already (how lucky is that??) - I used 2 wires for the siren, 2 wires for a data connection (VDSL from the house to the shop over copper), 4 for the databus connection - that leaves 2 free if needed.
I already had 2 runs tied into the databus on the ELK control -- one line (4 conductor) went to 2 in-series keypads. The second went to the GE wireless receiver. I added the third to the shop and at the other end I have a zone expander and then that line terminates with the keypad out there.
After doing all of this, I noted in the manual that there should be no more than 2 "homeruns" from the databus without a hub. I looked into the hub and I cannot, without serious drama, replace the 4 conductor wire with cat5 for the 2 existing keypads. The GE wireless receiver is connected via CAT5 so that would not be a problem, however. I could, as an alternative to the hub, daisychain the shop after the GE wireless receiver, so there would only be 2 homeruns - though I don't see what difference it makes.
As of right now - everything is working perfectly -- 1 line for 2 keypads, 1 line for the GE receiver and 1 line for the shop (M1XIN + Keypad.) Area 1 (house) communicates with its keypads and wireless zones just fine and Area 2 (shop) communicates with its keypad and zones fine.
Is this a could have problems down the line scenario, or if it works, it will continue to work? If the former, are there any suggestions for correcting the situation without tearing holes in walls and running new wiring?
Thanks for all of your help, as always!
