I'm having some trouble with the web interface. On the web tab I have the controller name and password set.
1. If I click on the Open web interface button it opens my browser and tries to navigate to https://localhost:9399/. After a short wait it times out and shows:
No data received
Unable to load the webpage because the server sent no data.
Here are some suggestions:
2. From another pc I navigate to https: //ip_of_mac:9399/Interfaces/Default/index.html (space added to stop CT from auto hyperlinking) and I get the invalid certificate screen. When I continue I get the authentication dialog. I enter controller name and password exactly as defined on the web tab and then I get a 404 error: The webpage cannot be found.
I have to be missing something, any idea? I do prefer to to have localhost work over the others.
I made assumption the interfaces directory and files are case sensitive and accessed it exactly as above (Note: the documentation and screen shots show different case and leaves the 's' off Interfaces). I've tried changing the controller name (shorten with no spaces), different passwords, etc and I get the same results.
No data received
- Reload this webpage later.
