So I have installed a Elk 28" can with a outlet mounted on the bottom.  The outlets ground is tied to the metal Jbox the outlet is in and the metal Jbox is secured to the metal Elk can.  Is this sufficient grounding of the Elk can?  Note the Elk can has no ground screw mounted on it.
Second box is a Leviton can that I mounted a similar outlet to the bottom. However the Leviton can actually has a ground screw on it but not in a great location for tieing back to inside the outlet Jbox. Do I still need to tie a wire somehow to that poorly located ground screw or is my ground Jbox sufficient?
Note in both cases I did confirm that the can has low resistance to the AC ground via a multimeter.
