Hi,
I've got 2 cans in my house that I'm remodeling (full gut) and to make things clean, I am planning on running 'home runs' to one of my cans and doing the zone splicing in the can (window+window+door = zone 1) and then sending one zone wire to the alarm panel in the other can (there will be zones closer to this can that will run direct to it).
Correct me if I'm wrong, but AFAIK, this is a good option to direct home runs for each contact since you can maintain the troubleshooting properties of having access to each line. Assuming that this plan is good practice, I have the following questions:
- In the first can with splicing, I'm assuming you can just use a butt splice connector, but are there alternate methods similar to a patch panel for networking? Something like this?
- I've picked out most of my components (Roughly ELK M1, Bosch ds835 sensors) but could use some recommendations for window/door sensors that don't drill into the new windows/doors that I'm ordering (mix of casement, dual horizontal siders, and a french sliding door and a french out swing door). I've accepted that you have to drill into the vertical sill of the window, but was thinking that an adhesive based magnet on the actual window part would suffice.
- What sensors work best for doors? I would ideally like a recessed option.
- Glass break sensors? How many and a brand suggestion?
