You could always install a plunger contact in the slot where the deadbolt rests when locked.
With the Kwikset locks, they send a confirmation that they have locked/unlocked back to the controller. If there is a door jam or failure to lock the Kwikset will not send this confirmation and the lock will not change statuses on the controller. Depending on the controller you are using you can setup a rule to repeat the lock command or to notify you in the event of a failure.
