Hopefully I am making a blaring newbie installation or setup error.
This is my issue. I have been purchasing Switchlinc (2476d) dimmers over the last 6 months or so to swap out all of my switches in my house. I am running everything off of a ISY 99i Pro which is setup and working fine. I just installed the first Switchlinc dimmer and I have one glaring problem. Upon installation I push up on the toggle to raise the light level, it responds and powers up to full brightness, however it will not stay there. As soon as its at full on, it immediately dims down to off once I release the toggle. My ISY finds the switch fine and I can bring it up to full on over the network and where it does exactly the same thing. Once I get to full brightness, it immediately dims to full off.
I have done the following to troubleshoot:
- Factory reset the switch
- Programmed the switch for brightness of 100% at full on.
- Completely Replaced the switch with a new one.
I figured it was possible I got a bad unit, but once I swapped it out and it did the same thing I figured I was more than likely doing something wrong.
Any help would be greatly appreciated.
-Lil'
-Lil'
