Well, this is my first post on this forum, so hopefully I am putting this in the right place...
To start with, I am a total newbie when it comes to the Elk products. I bought my house in 2009 and it was already equipped with an M1G and a touchscreen to control it. I had nothing to do with installing it, and the previous owners didn't leave me any documentation.
Since then I've tried learning a bit here and there about controlling it, but I am still sort of in the dark.
Anyway, last week I had a serious lightning strike very close to the house (although I don't think it hit the house). All my stuff is surge protected, but I believe this was inducted current on the low voltage circuits. I was actually home when this happened, and immediately the alarm speaker for the M1 system started going haywire. (Not a normal alarm sound, it sounded very unusual, like a piece of electronics dying, for lack of a better description) The only way I was able to stop the racket was by flipping the switch off on the M1G board itself.
Well, I troubleshot it quite a bit and determined that a simple reset wasn't going to do it. Even rebooting it, the horrible alarm sound would come right back when I flipped the switch on. I was unable to connect anymore via ElkRP and the touchscreen was also unable to connect. (Although I could ping the IP, which I assume runs on a separate board)
Reasoning that the M1G was blown, I ordered a new one (control board only) online. Finally got it tonight and put it in, using the terminal blocks off the old one so as to keep the same setup. Loaded it up in ElkRP, sent my saved programming to the device, and all is well. Well, except my thermostat doesn't seem to work with the M1 system anymore.
I have an HAI Omnistat 1 series. (122 I think?) It operates normally as a standalone unit, but I cannot seem to get it to respond to the Elk system.
Here were my troubleshooting steps:
- I have two M1XSPs. One for the HVAC, one for exterior lighting. Reasoned that maybe the M1XSP controlling the HVAC was dead.
- Powered off the M1 system entirely.
- Disconnected the 'known good' one that was running my lighting, and configured all of the jumpers and dip switches (address, baud rate, etc) identically to the one that was running my HVAC. Connected it up that way, making sure to move the terminator plug on the data bus to account for one less device.
- Fired up the M1 system.
- Verified that (as expected) I am no longer able to control lighting, but thermostat data is still not working.
- Removed HAI Omnistat from the wall and verify serial connection is still in place. It is. No visible damage or scorch marks.
- Replaced HAI Omnistat and verified that I am still able to operate HVAC. Still no thermostat data.
Does anybody have any idea how else I might test this? I am guessing I may need to buy a new thermostat, but I really am not looking forward to throwing more money at this problem without knowing what I'm doing. I'm already a few hundred in just with the M1G replacement.
