May 18 2005, 08:58 PM
Post
#1
Cocoonut ![]() ![]() ![]() ![]() Group: Moderators Posts: 5376 Joined: 12.24.03 From: Las Vegas, Nevada Member No.: 5 |
Dean Roddey, Chairman/CTO of Charmed Quark Systems has graciously donated a copy of his Charmed Quark Systems Software for a CocoonTech contest giveaway!
Information on what this feature rich software is all about and an introduction to its capabilites are described below. If you would like to enter your name for this contest please reply to this thread. The winner will be selected via a random drawing in approximately one week (please reply only once as duplicate replies will void your entry into the contest). Again, thanks to Dean for this very generous offer to our members! Charmed Quark Systems Software; Automation Solutions for the Home and Small Business Modern automation products are composed of three fundamental components:
But today the general purpose PC market, with its enormous competitiveness and ecomonies of scale, has created a situation where the DIY automation fan has available to him very powerful, small, inexpensive PC hardware, and very capable multi-tasking operating systems capable of managing many tasks simultaneously. Add to this the recent and ongoing arrival of very 'retro-fit friendly' specialized automation hardware, such as wireless and powerline based systems, and the DIY customer can easily put together a hardware configuration as or more powerful than that provided by traditional automation companies, for a far lower price. All that is missing is the software to tie it all together and put it all to work. Charmed Quark System's software-based control and automation product, CQC, is an example of the software brain your hardware configuration needs in order to convert it from a collection of hardware into a powerful automation solution. CQC actually takes the next step up in integration, because it is a fully network distributed automation system, meaning that you can install it on any machines in your network, allowing any machine to control devices, to take use input or output, to act as an administrative interface, and so forth. It actually turns your entire network (if you choose to make use of this capability) into a conglomerate automation system. In order to achieve this type of architecture, CQC is not a single program, it is instead a 'suite' of programs that can be installed on various machines in the network (or all on a single machine) to proivde various types of services where they are required. Here is a diagram that describes the types of components that make up a CQC system. They are deviced into 'back end' components and 'front end' components. Back end components run in the background and you never see them. They do things like manage devices under CQC's control, or wait for events to occur and invoke configured actions based on those events, and so forth. Front end components are the programs the administrator or user actually interact with: ![]() (Click on Picture for Full Sized Image) As shown in the above image, CQC is composed of really four fundamental components, a Master Server that provides central storage of system wide configuration, CQCServer which controls devices and makes access to and control of those devices available throughout the network, client side administrative and end user interfaces, and a set of optional components that allow you to do things like schedule things to happen at certain times or to control software programs through CQC as though they were devices. All of the user and administrative tools work in terms of the Master Server, so you can manage your system from any machine on the network where the administrative tools are installed. You can edit a macro and save it and it immediately becomes available throughout the system. Or you can make a change to an interface, or push a device driver out to a CQCServer running anywhere in the network. Here is a more detailed diagram of a two computer CQC system: ![]() (Click on Picture for Full Sized Image) You can see the Master server and CQCServer running in Computer 1 on the left along with the client tools, and CQCServer and the client tools running on Computer 2 on the right. Each computer is controlling three devices. CQCServer loads up device drivers from the Master Server, based on configuration, and provides access to those devices. CQC is sold as a base package plus options. The base package provides the following broad features:
Here are some sample screen caps (much reduced to keep the load times down) that demonstrate some of the features of CQC. Here is an example of a CQC graphical user interface. ![]() (Click on Picture for Full Sized Image) Except for the lamp image, it was built with images that ship with CQC. CQC user interfaces have no particular look and feel, and this sample is completely arbtrary in terms of what images where used, how they are presented, and so forth. Here is an example of the kinds of interaction effects you can create with the user interface system. ![]() (Click on Picture for Full Sized Image) Here is an example of the media management features of CQC that will be available in the upcoming 1.4 release. ![]() (Click on Picture for Full Sized Image) Here is an example of the weather feed capabitilies of CQC, based on the Weather Channel XML data feed. ![]() (Click on Picture for Full Sized Image) Here is an example of the upcoming .Net Interface Viewer, displaying some example user interfaces. ![]() (Click on Picture for Full Sized Image) You can find out more at the Charmed Quark Systems web site at www.charmedquark.com. In particular you might want to look at the Galleries section, from the main menu at the top. This section provides documentation and pictures on some real world CQC installations, so that you can see how it is used by actual customers. For more information on the devices supported by CQC, see the Support Devices Web Page. Click on a category to expand it and see the devices supported in that category. Upcoming drivers include the Elk M1 and the Escient Fireball media server. |
May 18 2005, 09:25 PM
Post
#2
Cocoonut ![]() ![]() ![]() ![]() Group: Registered Posts: 1886 Joined: 03.04.04 From: Maryland Member No.: 106 |
Sure why not... Put me in.
May 18 2005, 09:31 PM
Post
#3
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 666 Joined: 01.16.04 From: Chattanooga, TN, USA Member No.: 43 |
Me too
May 18 2005, 09:53 PM
Post
#4
Cocoonut ![]() Group: -= Gold Supporter =- Posts: 2441 Joined: 01.05.04 From: Orlando, FL Member No.: 21 |
me three please
May 18 2005, 10:42 PM
Post
#5
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 606 Joined: 01.25.05 Member No.: 465 |
Me, please.
Thanks, Dean, E & BSR |
May 19 2005, 12:48 AM
Post
#6
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 600 Joined: 03.06.04 From: Maine, USA, EARTH, MILKY WAY Member No.: 139 |
Count me in, and
Thank You for this and other opportunities to Dean, E, BSR, and AO, and all the people and sponsors who frequent the board! |
May 19 2005, 12:52 AM
Post
#7
Cocooner ![]() ![]() Group: Registered Posts: 60 Joined: 03.07.05 Member No.: 557 |
Please count me in.
Thanks, Kenny |
May 19 2005, 06:48 AM
Post
#8
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 228 Joined: 01.06.04 From: Newmarket Ontario Canada Member No.: 22 |
Sure - count me in and thanks !
May 19 2005, 06:58 AM
Post
#9
Cocooner ![]() ![]() Group: Registered Posts: 60 Joined: 01.12.04 From: Pottstown, PA Member No.: 29 |
Me as well please
May 19 2005, 07:08 AM
Post
#10
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 569 Joined: 02.13.04 Member No.: 55 |
QUOTE (huggy59 @ May 19 2005, 01:48 AM) Count me in, and Thank You for this and other opportunities to Dean, E, BSR, and AO, and all the people and sponsors who frequent the board! Couldn't say it better myself |
May 19 2005, 08:28 AM
Post
#11
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 794 Joined: 02.20.04 Member No.: 60 |
Sure, add my name to the hat.
May 19 2005, 08:35 AM
Post
#12
Cocooner ![]() ![]() Group: Registered Posts: 45 Joined: 01.15.04 Member No.: 38 |
Count me in and a big thanks to all.
May 19 2005, 09:29 AM
Post
#13
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 733 Joined: 08.24.04 From: silicon valley, ca Member No.: 255 |
i'm in
May 19 2005, 10:42 AM
Post
#14
Cocoonut ![]() ![]() ![]() ![]() Group: Vendors Posts: 1530 Joined: 03.02.04 From: Metamora, MI Member No.: 70 |
Count me in!
May 19 2005, 10:43 AM
Post
#15
Advanced Cocooner ![]() ![]() ![]() Group: Registered Posts: 189 Joined: 04.17.05 Member No.: 645 |
<27>\chr=HomerSimpson\ Contest? I love contests! Pick me, pick me! <27>\chr=computer\
(Thanks, Dean, that's a generous thing to do.) |
Lo-Fi Version | Time is now: 3rd September 2010 - 03:11 AM |
