KidCalledZero
I have all my Elk components and just finished wiring my first sub panel with my exterior relays.  I'm not sure if the way I wired it is going to work but it made perfect sense to me.  Here is what I have.
I have my M1RB relays controlling/triggering 912 relays with a dedicated and controlled 12V power supply through a P212S. I have 16 912 relays in a sub-panel that will control low voltage lighting and sprinkler valves. Running to the sub-panel from one of my Elk panels are 2 9 conductor 18 gauge cables. All the (-) are combined off the M1RB into a single conductor. I plan on using one condcutor for the common (-) and 16 of the other conductors for the voltage (+).
Once I get to my sub-panel I have the common run to my first relay and then simply jump from relay to relay connecting the (-). I also looped the last relay (-) back to the single conductor (1) coming into the panel. I assume this going to work since all the (-) are the same. Is this correct?
The (+) are wired individually to each relay that they control.
  h34r:
h34r:
