Hi guys I was searching trough the forums and got a lot's of great tips on how to mount the equipment, panels etc. I saw that most of you are using plywood. Now my question is what type of plywood is the best (strongest) and how thick it should be? I'm planning to mount 28" elk can with m1 gold, also 24 port network panel, power supply can for cctv, brackets for equipment such as dvr, nvr, routers, switches etc. Is 4'x4' 3/4 thick plywood enough for my needs? Also do I mount it directly to the concrete basement wall with couple of tapcon screws or do I need to mount couple 2x4 between the plywood and concrete because of the moisture issue? Thank's a lot
