So I have an equipment closet that is roughly 3' X 7'.  As you can imagine it has several computers and other gear in it and gets rather warm, especially during the summer months.  I just recently installed a bathroom exhaust fan, 50CFM, and louvers into the bottoms of the closet door.  The thinking here was that the exhaust fan would kick on, pulling air from the top of the closet, which would in turn pull cool air through the louvers and cause an overall cooling effect on the closet.  This has not worked out as planned.  I shut the doors for a few hours yesterday and the temp built up to around 90 degrees.  I then kicked the fan on, expecting air flow, circulation and cooling, but an hour later the temp was the EXACT same!  I tested the fan to be sure it is actually moving air by placing toilet paper across it and yes, it is working as it should.  I even got into the attic to check the other end and there is air being pushed out.
My thought here is that what is happening is that the cool air is being brought in and sucked into the updraft from the fan and not circulating throughout the closet, so no cooling is actually happening. My next thought is to put a small desk fan into the closet near the louvers to get the air circulating lower in the closet so that the updraft from the fan does not just suck the cold air up (As it appears to be doing now).
I am a little at a loss here, because the theory behind what I did should be sound. Hot air rises and so on.
Any thoughts here?
Any thoughts here?
