I have some Leviton scene-enabled X10 dimmers that I would like to use with Premise. This includes devices like the HCP03 plugin dimmer and the HCM06 universal dimmer. While these devices are not state of the art, this stuff was relatively expensive at the time, and the devices still work fine.
I would like to take advantage of the scene capability of these devices, as a scene command operates faster than controlling the devices individually with a Premise scene or script. However, I can't figure out how to send the extended code functions. I hope this is making sense. I apologize if I am not using the right terminology...
For example, if you are familiar with heyu in Linux, it would be a command with the syntax "heyu xgrpexec B 0.7". Is there an equivalent way to issue such a command with Premise?
When I issue the heyu command above, it shows up as the following in PortSpy:
Any help would be much appreciated.
Code:
5A
C3
C3
05 01 E7 00
26 36
