CharlieGulf
I have a new home under construction, and I’m looking for some guidance in pre-wiring for an alarm/automation system. In the short term, I’m mainly interested in making sure all the wires are in the wall for alarm keypads, door/window contacts, etc. However, I was told it’s best to select a panel before completing the wiring. I was originally planning on a simple DSC or Honeywell alarm panel, but some of the features of the ELK or HAI panels look like they might be useful in the future. Nevertheless, founds are limited, and I don’t want to spend a lot all at once, on something way beyond my needs, if I can help it.
I have about 14 windows and 2 doors in the house. In the semi-detached garage, there are 3 windows, 2 doors, 2 garage doors. I would like to home run the contact wires from all of them to my panel location. I’ll need at least two, probably three keypads.
I’m unsure if I should run the sensors/contacts in series at the panel or one sensor/contact per zone (thus needing a lot of zones on the panel). I’m also debating whether or not to use end of line resistors. I’m unsure how I would even install them with each sensor/contact running back to the panel. Most of the examples I’ve seen are using daisy-chained contacts.
After moving in I’d like to have gate control, camera, and intercom from two driveway gates. One is over a 1000ft. away from the house and shared with another house, and another will be placed only a few hundred feet away after construction. This doesn’t have to be done with the alarm panel, but it would be nice to integrate them if practical.
Some options I might like to do in the future include:
-Controlling outdoor lights with a timer automatically adjusted for sunrise and sunset.
-Connecting the lights on the wrap-around porch to motion sensors on the porch for security.
Again, my main concern is getting the wiring right, and choosing a panel; something for basic security in the short term, and expandable for future automation. I’d appreciate any suggestions and information you have.
Thanks.
Thanks.
