So this is where the comments I made in another thread about individual zone programing and EOLs want to bite me in the rear. I want to hookup my doorbell to the OPII via the Elk-930 doorbell detector that I have. The 930 connects to an input zone as follows:
So the zone needs to be NO. In order for me to configure a zone on the OPII as NO that means I have to turn resistors (EOL) on and in my case that means adding resistors to the panel which I simply will not do. I don't know if I can use a relay or something to change this to use a NC zone so I figured before I try a bunch of things I figured I'd ask if anyone is using a 930 with their OPII or how else you connect your doorbell to the OPII. It would be so nice if the Omni panels could let you choose EOLs on a zone by zone basis!
Edit: I should add that it is a lighted doorbell.
			Connect the output of the 930 to the zone input terminal. You will also have to connect the negative of the 930 to a negative terminal on the M1. Configure the zone as a normally open zone. Maybe a "Do Nothing Zone Type".
		 Maybe you are right and the docs are wrong? I guess it wouldn't hurt to try it. I've already tried using the 930 to trigger a relay then realized it doesn't output any voltage, so I also tried adding 12V and having the Output on the 930 act as its own relay and figured it would be open then closed on doorbell press. So I figured that when the doorbell was activated it would close the output on the 930 which would put 12v to the relay which would open it but that failed to. It seems the 12v was constant, like the 930 Output was not really open since the relay was activated all the time.
