Hi,
After hours of searching the web, I have found two modules that connect to a Honeywell VisionPro IAQ thermostat that seem promising in terms of communicating with the M1G. One is an RS232 module (W8735A1005), the other is a web/ethernet converter (EnergyICM).
Links are as follows:
RS232: http://customer.honeywell.com/techlit/pdf/...00s/68-3063.pdf
EnergyICM: http://www.in2networks.com/PDFs/PDF2.pdf
My big question now is if there is any interest at Elk to produce drivers to communicate with the IAQ via either module, or if that would be something that the community would have to do on its own? If the latter, how difficult is it to program something like that?
I have received the RS232 API from Honeywell for the W8735A module, in which they sent a bunch of 'C' code, which I would guess would have to be rewritten into something the M1G could understand.
I'm not sure what kind of communication one can do with the EnergyICM, but if it has a web interface, I wonder if the M1G could communicate to it via the M1XEP module?
Does anyone have any ideas?
Eric
Eric
