I picked up 2 Harmony remotes a while ago for about $30 each. They are the Harmony 520 and I like them a lot but I need RF in my setup.
So I bought 2 of the battery transmitter RF extenders (shown here). They are available in two frequencies so I can keep the remote signals separate to avoid equipment conflicts.
This worked pretty well but they use 2/3 AAA rechargeable batteries which after a while don't maintain a charge very well and cause the other batteries to deplete faster. So I decided to permanently integrate the transmitter into the remote.
There is not much room inside the Harmony 520 but luckily the transmitter board is pretty small once you remove it from the battery casing. Then there is a spot for it in a popout area of the casing.
So then I rewired the batteries so that one of the AAA batteries takes the place of the 2/3 AAA, insulated the transmitter with some electrical tape, and put it back together. Now I can just use 4 normal AAA batteries and hopefully get more battery life and stronger signal out of the transmitter since it is running on 1.5v instead of 1.2v.
Working well so far.
The output of the RF receiver is then tied into an IR distribution system and I can control everything with no exposed receivers and from multiple rooms.
Seemed like the ideal solution for me so thought I would share.
Total cost: ~ $65
Cheapest RF Harmony Remote: $200+
Total cost: ~ $65
