miamicanes
I'm pulling my last wires before getting ready to hang the new drywall, and making my final "wish list" for future projects. I only HAVE to have a single smoke detector, but I wouldn't mind adding a few more if it wouldn't end up being enormously more expensive.
I know that it's trivially easy to connect a single 2-wire or 4-wire 24v smoke detector to the Elk M1G... but what does adding #2 and beyond entail? I've kind of gotten the impression that, among other things, you have to ALSO add expensive relays that cost more than the detectors themselves, but I'm not sure whether I was misunderstanding what I read, or whether the relay-requirement only applies to 2-wire or 4-wire alarms.
Likewise, if 110vac is readily-available from a nearby junction box, would 110vac detectors be easier/cheaper/better, or would I just be adding new, expensive headaches to the equation?
Do I just need to run a cat5 cable to each future/potential smoke detector location (terminating them all in the same panel), or does each detector need TWO cat5 cables?
Do 24v smoke detectors normally get screwed to the wall over a hole from which the cat5 pokes out? Or are they normally/always installed over octagon boxes, pancake boxes, or something else?
For what it's worth, the area we're talking about here is the second floor of my house. It's a townhouse with front and rear bedrooms, and bathroom+hall+stairs in the middle. The current (battery-powered) smoke detector is in that hall, and that's basically where a single new detector wired to the M1G would go as well. The proposed locations for two additional detectors are the two bedrooms; each proposed additional smoke detector would be a whopping 15 feet or so away from the one in the hall -- we're not exactly talking about a large mansion here. Ergo, the reason why I could go along with spending an extra $35 or so per room to throw up a second and/or third one in the bedrooms if all I need is the cat5 and the detector, but why I'd seriously balk at spending way more than that just to add detectors #2 and #3 just a few feet away from detector #1 (for what it's worth, I don't smoke or use space heaters, which pretty much eliminates the 2 biggest causes of fires that start in bedrooms anyway).
