skyewright
Hi,
I'm slowly setting up a 1-wire system using owfs.
Temp, humidity and pressure are reading fine. I'm also reading a value I can interpret as a direction using an Inspeed e_Vane attached in place of the humidity chip on a T/H/S board.
The problem has come up now I have started to add in windspeed using an Inspeed Vortex connected to the HB Dual Counter board.
Counters A & B are jumpered together.
Counter A and +5V are connected to the Inspeed Vortex.
DQ goes to the DQ connector on a temp/hum/solar board
GND goes to the GND connector on a temp/hum/solar board
OWFS can "see" the DS2423, but counters.A gives a response of "Invalid Argument".
If (as suggested by Eric in this post ) I use OneWireViewer and go to the Memory page, I see the following in the status bar.
Any ideas or suggestions.
com.dalsemi.onewire.adapoer.OneWireIOException: Invalid CRC 16 read from device
