I had just hooked up a new RC-1000 and having an issue with it. It is wired as a basic single stage conventional stat. It is replacing a Honeywell VisionPro and the wiring is identical. The problem is when turning the mode to Cool, I hear the relay click and all appears to work, but the compressor does not turn on. I actually hear a slight hum or buzz from the compressor unit but nothing else. Thinking it may be an issue with the compressor I decided to put the Honeywell stat back first. When I did, it worked fine again. So it appears like it wants to work just the compressor won't kick in but everything else including the fan works fine. Any ideas?
		 So I turned the backlight down to 5 just for good measure and hope it continues to work. Maybe it was something hinky with a loose wire or something??? Anyway, as long as it works. Thanks!
