Quixote_1
BACKGROUND:
I'm building an automatic door entry system that will use keyless entry and incorporate a door-strike, two electric deadbolts and a linear actuator to open and close the door. The system will run on a marine deep-cycle battery so that I will still be able to get in if there is a power failure and will communicate wirelessly with my computer to keep track of who is arriving and departing so that it can arm my alarm automatically when there are no occupants in my flat.
QUESTIONS:
If anyone here is familiar with the inner workings of linear actuators (not any model in specific), I would really appreciate any advice that you can offer before I make my order. I've pretty much figured out everything else, but I'd like to know if and how I can use (built-in) limit switches and a (built-in) potentiometer. Can I use the limit switches to see what position the actuator is in? Can I use the potentiometer somehow to stop the current to the actuator so that I don't accidentally cut off someone's fingers in my door?
I've already found a circuit to use a relay to reverse the current the the actuator that I will use with a ratchet relay so that I can get movement in both directions... so far, so good.
Thanks for the help!
QUESTIONS:
