BraveSirRobbin
Moderator
I'm in need of a way to have a common voice announcement speaker distribution used for the Elk M1 Gold announcements as well as voice announcements from a HomeSeer computer (via its sound card output).
I'm using an Elk-800 amplifier with its output connected to four Elk Echo Speakers (for a total of two ohm load which is at the rating of the amplifier).
I needed to somehow share the input of this amplifier with the computer's sound card output and the Elk Voice Output #1.
To do this I arranged a circuit to have Output #1 be at a pre-amp level (saw an Elk “How-To†on this somewhere). I then used the on-board single pole double throw relay (Output #3) to switch between the two sources (Elk preamp output and the sound card output). Refer to attached schematic below for details.
I then adjusted the sound output of both the Elk M1 Output #1 and the computer as well as the overall gain of the Elk-800 amplifier so both voices were uniform while achieving desired volume at the speakers.
Then whenever I want the computer to take over the announcement system I just turn output three on before sending any voice announcements (no big deal, since the computer voice announcements are done via script anyways).
This works well, but there are three problems that I need some input and advice on.
First, I'm using the my.elk script for turning output #3 on and can only find a command for turning an output on for a limited time. Is there a command to turn it on without a timeout?
Second, there is a distinguished (i.e. not loud, but noticeable) "pop" during the start and end of all the Elk announcements. I know it’s coming from the Elk output #1 as I connected headphones right to that output (with nothing else attached).
I played around with various capacitors in the amp, speakers, elk, etc... but could not get rid of this.
Third, is there some way to enable and disable the Elk voice announcements so they only occur for a certain time of the day? I know I can write a rule to do this, but would rather not (I'm using 45 zones for this house).
I was thinking about using output seven via a relay to control the power to the Elk amplifier so it was turned on during the "daytime and evening" hours only. Is there a better way?
How is everyone else interfacing their HA voice announcements with the Elk announcements?
BSR
BSR
